my featureReader only display 20 rows when the total hits are 2006. It is basically searching for company name 'chevron' or 'exxonmobil'. I have featureReader format as JSON
  • May 28, 2019 7:39 PM UTC
  • 53 views
Here, you can see that total hits for 'chevron' is 1910 and 'exxonmobil' is 96, but on the output, it only gives 20 rows. 10 rows for each Company name
danilo_fme
Forum|alt.badge.img+58
  • May 28, 2019 10:05 PM UTC
Hi @zatom
Could you share us the log file to inspect better your situation?
Thanks,
Danilo
nampreetatsafe
Forum|alt.badge.img+14
Thanks for your question @zatom! As @danilo_fme mentioned, it will help if you provide your log file. Would you mind sharing your workspace (.fmw file) with us so that we can see what parameters you have set for each transformer?
