MultiSurface to WKT MultiPolygon
  • Oct 23, 2018 8:17 AM UTC
  • 574 views
Dear all,
At this moment i'm trying to convert a CityGML (MultiSurface) to a WKT.
Unfortunately I get Multilinestring instead of MultiPolygon. What am I doing wrong?
This is my workbench
  • Oct 23, 2018 8:27 AM UTC
If you send the output from the CityGML reader to an Inspector, what do you see? Lines or polygons?
Eiter way, you can try inserting a GeometryCoercer set to fme_polygon just after the Reader and see if that makes a difference. Attention: the GeometryCoercer doesn't support aggregates (multi-part geometries), so you may have to use a Deaggregator first and an Aggregator (Group By on the _part_number attribute) after.
  • Oct 23, 2018 11:55 AM UTC
@david_r it works! Thanks a lot.
GeometryCoercer and then delete the default Geometry XQuery....
