MultipolygonZM to multipolygon (2D)
  • March 16, 2017
  • 290 views
Hi.
I want to write data in a PostGIS table with geometry as multipolygon (2D). These data come from Esri shapefile that contains 3D polygon according to ogrinfo.
I use an intremediate PostGis table written by FME (Insert setting with Drop and Create table setting). The geometry obtained is a MultiPolygonZM. Using the 2DForcer transformer results in a MultiPolygonM geometry. But the next data management in PostGIS (ending up with insert into final table) returns the error "Geometry has M dimension but column does not".
Is there a way to remove the M coordinate in FME (or to avoid to read a 4D geometry in the input shapefile), rather than to use a ST_force2D in each PostGIS post-treatment.
Thanks
Forum|alt.badge.img+63
Have you tried the MeasureRemover transformer?
