Multiple output tags in custom Python transformer ?
As my alter-ego "lifalin2016" i brazenly proclaimed in a post in June that "I have the multiple OUTPUT tags option covered". This is unfortunately not really the case (anymore).
The PythonFactory documentation clearly states, that multiple output tags are possible (as in the "[...]*" notation), but I get an error when using them: "The clause 'OUTPUT PYOUTPUT ...' is incorrect.  The OUTPUT PYOUTPUT clause is already specified". I assume the doc is faulty then.
It's then back to a single output + a number of TeeFactory's. I seem to remember this being mentioned by one of y'all at some point, but I can't seem to locate it anywhere :-/
Unfortunately my experience with factories is limited, but here's my best shot (using an attribute named "___output_type___" to route features to the output tags SUCCEEDED and FAILED. But no features are output :-(
# after PythonFactory
FACTORY_DEF * TeeFactory
   FACTORY_NAME $(XFORMER_NAME)_Splitter1
   INPUT FEATURE_TYPE * ___output_type___ 1
   OUTPUT FEATURE_TYPE SUCCEEDED
   FACTORY_NAME $(XFORMER_NAME)_Splitter2
   INPUT FEATURE_TYPE * ___output_type___ 2
   OUTPUT FEATURE_TYPE FAILED
Any help on this is appreciated.
Cheers
Lars I.
Best answer by gispro
Hi again,
Well, posting a question gives one time to pause and regroup ones thoughts, I suppose.
I managed to work it out, and is posting the resulting combination here for others that have the same need:
FACTORY_DEF * PythonFactory
    PYTHON_NAMESPACE FMEOBJECTS
    SYMBOL_NAME MyApplication.__instance__$(FME_UUID)
    OUTPUT PYOUTPUT FEATURE_TYPE ___from_python___
   INPUT FEATURE_TYPE ___from_python___ ___output_type___ 1
   OUTPUT FEATURE_TYPE $(OUTPUT_SUCCEEDED_FTYPE)
   INPUT FEATURE_TYPE ___from_python___ ___output_type___ 2
   OUTPUT FEATURE_TYPE $(OUTPUT_FAILED_FTYPE)
You set a feature attribute named "___output_type___" to a value of 1 or 2 before outputting the featurew with self.pyoutput(). The TeeFactory's route the features based on this value to the relevant output tag of the transformer.
Cheers.
  • March 12, 2017
Hi again,
Cheers.
That's pretty fancy, would you perhaps share an example of how that would be implemented in a small sample workspace?
