Multiple geometries with different SRSID ?
  • Nov 16, 2016 3:43 PM UTC
  • 13 replies
  • 188 views
lifalin2016
Forum|alt.badge.img+42
I've aquired the task of populating a MS/SQL table with four (!) geometry columns.
I've looked at this article, which helped me get going.So far so good, the 4 different geometries get saved as they should, and STAsText() returns the correct coordinates.
But when I look at the geometries' SRSID, i.e. using the geometry::STSrid property, they're all zero (0). Including the original unaltered geometry read from the source.
Is there a way (in FME) to set the individual SRSID on each geometry, so each target column has it's own SRSID ?
Cheers
Lars I.
itay
Forum|alt.badge.img+19
  • Nov 16, 2016 4:10 PM UTC
Not sure but could be that you are looking for the coordinatesystemsetter?
lifalin2016
  • Nov 17, 2016 7:35 AM UTC
Well, the input data have a set coordinate system, and the reprojected have that reset to the target system (I assume). Wouldn't it be adding what's already there ?
lifalin2016
  • Nov 17, 2016 2:16 PM UTC
Nope, sorry. Didn't change anything.
itay
  • Nov 17, 2016 4:25 PM UTC
Are you using FME or the underlaying db to define the output coordinate system? as mentioned in the article
  • Nov 17, 2016 4:36 PM UTC
Maybe this article can give you some pointers, if you haven't read it already: https://knowledge.safe.com/articles/28728/writing-to-tables-that-contain-multiple-geometry-c.html
lifalin2016
  • Nov 21, 2016 9:52 AM UTC
That's the article I started out with :-)
lifalin2016
  • Nov 21, 2016 10:43 AM UTC
I'm uploading a workspace + a Shape table with test data + a SQL query script which includes the target table definition and a sample query. The target is an MS/SQL, which you'll have to provide (Express will work, I think).
The table has four geometry columns, two pairs of geometry + center point in each projection.
The query shows that the SRID is 0 as-is for all four geometry columns.
The query also shows, the if saved with an non-zero SRID (the "wkt" columns), the SRID is non-zero upon request.
Cheers
Lars I.
lifalin2016
  • Nov 21, 2016 10:49 AM UTC
Cheers
Lars I.
test-multiple-table-geometries.zip
itay
  • Nov 21, 2016 11:13 AM UTC
I would contact Safe for this issue http://www.safe.com/support/
erik_jan
Forum|alt.badge.img+26
  • Nov 21, 2016 6:36 PM UTC
I have done a similar process before.
The only way I could get this done is writing the record with a single geometry (and SRID).
Then writing the other geometry using a writer in UPDATE mode (or a DatabaseUpdater transformer) adding the second geometry (with a different SRID) to the existing record.
mark2atsafe
Forum|alt.badge.img+59
Yes, please do contact support. I looked into the issue but I don't see any existing reports of this and nothing from our developers. The only thing I saw was when the SRID was not in the FME coordinate systems and didn't have an EPSG number - but I think that's unlikely to be an issue for all four of your coordinate systems. I think we'll need our SQL Server developers to comment on the issue.
Mark
gio
Forum|alt.badge.img+15
  • Nov 22, 2016 5:10 PM UTC
I haven't tried different SRIDs for multigeometrycolumns.
wkt can't pass SRID's. Afaik only extended Wkt wich fme does not use. In fact fme uses old one (at least in 2015)
Either build SDO_GEOmetry strings. Wich i did to by-pass the wkt extractor limitation using external (not in database) geometries , tough not easy.
Better yet use a update function.
Run it after it is written to the tables.
UPDATE tabelname T
SET T.geometryname.SDO_SRID = YOUR_SRID
WHERE T.geometryname IS NOT NULL
revesz
Forum|alt.badge.img+22
  • Jan 16, 2018 4:35 PM UTC
I have the same issue in SQL Server (FME 2017 & 2018).
I have a point feature type. I can write it with proper coordinate system as single geometry.
When I try the multiple geometry (the modified geometry has the same coord sys) the SRID becomes 0.
I tried to set the coordinate system at several points (writer parameter, CoordinateSystemSetter after the reader, before the writer, after the GeometryPropertySetter, before the Aggregator) without any success.
I ended up with the
update <table> set <column1>.STSrid=<SRID>, <column2>.STSrid=<SRID>;
SQL Command After the Translation.
