Multiple files to read as a parameter
  • Mar 6, 2020 10:03 AM UTC
  • 57 views
fikusas
Forum|alt.badge.img+5
Is it possible to read in multiple files from a parameter with FeatureReader? For example:
C:/some_path/fileA.shp
C:/some_path/fileB.shp
SourceDataset parameter value would be: C:/some_path/fileA.shp,C:/some_path/fileB.shp
But this approach doesn't work, it gives an error.
Forum|alt.badge.img+54
  • Mar 6, 2020 10:28 AM UTC
To pass a list of files as a parameter each filepath would be wrapped in quotes then the list is wrapped in quotes separated by a space
e.g.
""C:\Temp\File1.tab" "C:\Temp\File2.tab""
fikusas
  • Mar 6, 2020 12:45 PM UTC
Is it possible to get combined paths via private attribute using Python script? I use this code, but it doesn't work:
import os
shapefile = FME_MacroValues['SourceDataset'].split("\" \"", 1)[0].replace("\"\"", "")
return os.path.dirname(shapefile)
