Multiple Attribute pivot
  • Apr 17, 2019 12:22 PM UTC
  • 114 views
mukhtarg
Forum|alt.badge.img+4
Hello.
I have a file in which I have 3 columns a8_admin_name, cat and Subcat. Out of which i want to Cat column to be in Row and get its corresponding count for that particular a8_admin_name and then also get the same count for Subcat field for that particular a8_admin_name. Any help in this regard?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @mukhtarg, thanks for your question. Just wondering if you've seen this article that works through an example of table pivoting. It seems quite similar to what you are trying to achieve.
https://knowledge.safe.com/articles/31702/pivot-table-using-fme.html
Hope it helps. Cheers,
