Multicurve to Multiline Geometry Conversion
  • Sep 27, 2016 3:02 PM UTC
  • 6 replies
  • 1552 views
How can I convert a Multicurve geometry type to multiline geometry type?
  • Sep 28, 2016 9:35 AM UTC
Hi @vojvod, in the FME geometry model classification, MultiCurve is a collection of Curve geometries, and Line is a kind of Curve. See here to learn more: FME Geometry Model
I'm not sure what "multiline" in the context means, but the ArcStroker might help you if you want to transform Arc(s) within a MultiCurve to Line(s).
mark2atsafe
Forum|alt.badge.img+59
I agree. I don't think FME itself has a Multiline geometry type. Can you explain why this is necessary? Are you writing to PostGIS and want a multiple geometry of a particular type?
arnold_bijlsma
Forum|alt.badge.img+16
I have the same problem. I'm trying to write a set of unconnected related lines ("multiline" or "aggregate line") into a gdb, but getting an error about "multicurves".
A good example of a multiline (I think) is the land border between Canada and the US.
geo-x
  • Jul 30, 2018 11:50 AM UTC
Dear FME community, I've the same problem and I don't find what kind of FME geometry is compatible woth Postgis Multilinestring. Have you find the solution since last year ?
hordor
  • Dec 8, 2022 11:56 AM UTC
I had a similiar problem when writing to PostGis. I have a shape-layer which will be recognized as Multilinestring when read by QGIS. In FME it appears as FMEMultiCurve. FMEMultiCurve cannot be written to PostGIS Multilinestring - even when there are only lines in it.
Here is my solution:
First use Deaggregator, then Geometryfilter to be sure there are only lines, then reaggregate with Aggregator.
cheffing
Participant
  • Participant
  • Jul 3, 2023 6:53 AM UTC
Same problem ...
for me worked:
  • GeometryFilter to select only the lines
  • Aggregator
  • Deaggregator
Then I got in postgis:
  • LineString
  • MultiLineString
and all geometries were fine.
