Most common network_id from NetworkTopologyCalculator?
nicholas
Forum|alt.badge.img+13
I am using NetworkTopologyCalculator to categorise streets by what network they are a part of, with the aim of only keeping the main network and discarding the islands.
How do I determine the most common network_id value?
And then how to I place that value into an AttributeFilter to only keep those features?
jdh
Forum|alt.badge.img+28
  • June 25, 2020
The documentation doesn't say, but it's been my experience that the largest network is always _network_id 1.
drc43
Forum|alt.badge.img+11
  • June 25, 2020
You could run it into a StatisticsCalculator and search for the Mode. That would show which network_id value occurs the most. Then just filter based on that.
Forum|alt.badge.img+39
  • June 25, 2020
That's been my experience too, but I'm not sure if it's 100% always the case.
nicholas
  • June 25, 2020
StatisticsCalculator Mode does give me the correct value, thanks!
But how do I pass that value to the AttributeFilter?
@nicholas You can't rely on _network_id = 1 being the dominate network. It usually is, but this is probably only because the first feature to be processed is more likely to be on that network. @drc43 's suggestion of using the StatisticsCalculator Mode and then test the output from the Complete port for _network_id = _network_id.Mode is probably the safest route.
It is possible that you have more than one valid network (perhaps the networks do not connect at a pump station or you have several feeders). In this case, use the StatisticsCalculator Total Count and Group By _network_id. Then you'll have to estimate how many segments are likely to form a 'valid' portion of the network.
mark2atsafe
Forum|alt.badge.img+45
You'd probably use a Tester instead, but either way the value should be an attribute available in the Tester or AttributeFilter parameters.
nicholas
  • June 28, 2020
Thanks for the confirmation @markatsafe
The StatisticsCalculator calculates the mode as an attribute value. How do I then use that attribute vale to select features with that _network_id?
I thought I could use an AttributeFilter, but I don't know how to convert the output of StatisticsCalculator into the value for AttributeFilter
  • June 29, 2020
You just want to use the Complete Output Port from the statistics calculator
  • June 29, 2020
nicholas
  • June 29, 2020
@ebygomm, your suggestion of combining StatisticsCalculator (calculate mode) and FeatureMerger (the mode becomes the Supplier to the FeatureMerger works. Thanks!
Basically, FeatureMerger merges the output from NetworkTopologyCalculator (_network_id) with the output from StatisticsCalculator (_mode) and the only features that are merged are the ones where _network_id = _mode
I'm trying to accept it as the best answer, but there isn't an Accept button next to your answer :-(
Anyway, anyone else looking at this, you have to click on the image links to see the answer set out properly
  • June 30, 2020
I actually meant to remove that answer, if you are using the mode there is not need to use the featuremerger at all.
