MongoDB - delete record
  • Aug 2, 2017 1:40 PM UTC
  • 8 replies
  • 98 views
I tried to delete the record from MongoDB collection setting the fme_db_operation = Delete.
But the error is:
'fme_feature_operation' has invalid value 'Delete'. Possible values include: 'Insert', 'Put'
Setting the "Table Handling" = "Drop and Create" could help as bypass, just rewriting the records that should not be deleted. But I don't like that I need to rewrite something shouldn't be deleted.
Any better ideas?
Best regards,
Irena
  • Aug 2, 2017 1:55 PM UTC
Did you set feature operation accordingly?
Yes. The error mentioned above would be the result. It seems that no delete is available for MongoDB, or I'm wrong?
  • Aug 2, 2017 2:02 PM UTC
Which version of FME are you using?
FME Desktop 2017.0.1.1 (32-bit) - Build 17291
  • Aug 2, 2017 2:05 PM UTC
Excellent question, the docs aren't very clear about it: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/mongodb/mongodb-ft-param-w.htm
Hopefully someone from Safe can help... @RylanAtSafe @NatalieAtSafe
trentatsafe
Forum|alt.badge.img+7
Hi @irena_mitton
FME currently does not support update and deletes with MongoDB yet, even with the presence of the fme_db_operation. I have filed a PR to rectify the documentation, to better document the MongoDB operations we currently support.
In the meantime, if you would like MongoDB Updates and Deletes to be implemented into FME, please create an idea over on the ideas page: https://knowledge.safe.com/content/idea/list.html
Developers use this when looking at which features should be updated with new functionality!
I hope that helps.
Hi @irena_mitton
I hope that helps.
Thank you! Yes, at least just to know and eventually add the feature in the next version. ;)
The update itself is available for MongoDB (FME Desktop 2017.0.1.1) by setting "Feature Operation = Put" and "Table Handling = Use Existing".
trentatsafe
Hi @irena_mitton,
There is a subtle difference between Updates and Puts for MongoDB.
If the existing record is : "A" : 'a', "B" : 'b'
and you have a new record : "B" : 'b', "C" : 'c'
Put will change the results to:
"B" : 'new b', "C" : 'new c'
Update would change the results to:
"A" : 'a', "B" : 'new b', "C" : 'new c'
I hope that helps.
