Modify the parameter of "Geographic Transformation Gallery"
How to Modify the parameter of "Geographic Transformation Gallery"?where ?
Forum|alt.badge.img+63
Could you elaborate a bit? I'm not sure I understand your question.
  • August 24, 2017
In CsmapReprojector, the transform method "Beijing1954/a_to_WGS84", I need to modify the parameter of it, how to do it ?
Okay, it sounds like you need to add a custom transformation, see here for instructions on how to do that, although this form can save you some time.
