Merging Polygon Data
  • November 16, 2012
  • 24 views
What transformer(s) do I need to merge two polygon layers together where the coincident polygons would have both their original attributes and the attributes of the other polygon?  Thanks!
fmelizard
Forum|alt.badge.img+19
  • November 16, 2012
A Matcher with the list option on the singel matched output should do the trick.
erik_jan
Forum|alt.badge.img+18
  • November 19, 2012
Another option is the AreaonAreaOverlayer.
davideagle
Forum|alt.badge.img+21
  • November 19, 2012
You'll also be able to get this to work with the Clipper...
