merging fatures which have the same attribute value
  • Apr 5, 2018 10:50 AM UTC
  • 149 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have a network where this are many connected lines on nodes
I wanna make from the ones having the same value of an attribute to get connected and became one feature.
Is there any way to do it ?
Thank you
Best answer by dustin
If the lines are end-noded, you can use the LineJoiner with the Group-by option set to the attribute you want to join by.
danilo_fme
Forum|alt.badge.img+58
  • Apr 5, 2018 11:44 AM UTC
Hi @lianaolianov,
I believe you can work with spatial transformers to get the attributes.
For example, the transformer SpatialRelator. You can choose the Spatial Predicates to Test = touches.
And enable the option Generate List.
Thanks,
Danilo
lianaolianov
  • Apr 5, 2018 12:31 PM UTC
Hi @lianaolianov,
Thanks,
Danilo
Can you explain to me please a little more how to do with details ?
Thank you
danilo_fme
  • Apr 5, 2018 1:17 PM UTC
@lianaolianov,
I created here a Workspace to show about this process.
In my Workspace I used two shapefiles : Lines and Nodes. You can see the attributes associate in Lines and Nodes.
After I used the transfomer SpatialRelator to check the lines are connected with nodes.
Inside parameters on these transformer I selected the option Generate List, because I want to get the attributes from Nodes.
A Tester transformer was inserted in Workspace to filter the lines are connected _related_candidates >= 1.
The results in FME Data Inspector with all attributes ( Lines and Nodes ):
Attached the Workspace - workspace-spatialrelator.fmwt
Thanks,
Danilo
dustin
Forum|alt.badge.img+36
  • Apr 5, 2018 2:50 PM UTC
