Merging different segments
  • May 9, 2024 2:25 PM UTC
  • 109 views
olivier2
Dear,
I want to merge two different datasets. One data set has road segments with a maximum speed and the other is bike segments. For each bike segment I want to know what the maximum speed is on the nearby road segment. Now I want to merge for each bike segment the road segments that are near (next to each other) I have tried anchored snapper but that does not work 100procent. Do you have some ideas on how I could take this problem on?
Thank you in advance
(purple the road segments, pink? the bike segments) Only the segments that are parallel to each other should be combined
liamfez
Forum|alt.badge.img+44
  • May 9, 2024 6:32 PM UTC
You could try the custom transformer that @ctredinnick recommended as a solution on this post:
The LineOnLineRelator.
I have not used it yet myself but the way @ctredinnick described it, and looking at it on the hub, it seems like it may be what you are looking for.
olivier2
  • May 9, 2024 6:34 PM UTC
Thank you very much, I will try it!
