Merging CSV files
  • November 12, 2013
  • 9 replies
  • 268 views
I have 6 CSV files that contain just X,Y,Z (no ID fields).
I want to merge all the files into one large CSV file, but the transformers I have tried: FeatureMerger and Joiner appear to require an ID field to match common IDs.
Does anyone know of a simple Transformer that just lets me add all the XYZs into one file?
Thanks
  • November 12, 2013
a couple of alternatives:
  • if the X,Y,Z values are exactly identical in all the CSV files, you can concatenate the values (e.g. StringConcatenator) and use the resulting string as an ID for a FeatureMerger or InlineQuerier.
  • if the X,Y,Z values vary somewhat, send all the features through a 3DPointReplacer to convert them into point geometries and then use a NeighborFinder with a suitably small tolerance to group the features that are within the tolerance value from each other.
David
fmelizard
Forum|alt.badge.img+22
  • November 12, 2013
You can use the UnconditionalFeatureMerger, or just create a dummy ID and use the regular FeatureMerger.
Also a possibility is to read them as XYZ, use the PointCloudCombiner and write to csv.
Also the AttributeAccumulator with a dummy ID might work.
Itay
  • November 12, 2013
Thanks guys.
How do I create a dummy ID? each csv has 1 million rows, so I don't want to do it manually...
thanks,
fmelizard
  • November 12, 2013
AttributeCreator> attribute name: ID, attribute value :1
  • November 12, 2013
Also, when I try merging 2 csvs with just one row each of data using AttributeAccumulator and a Dummy ID field, my output CSV is empty.
  • November 12, 2013
I'm not sure I understand what you really want to achieve, but do you only want to merge all 6 CSV files into one big output file?
If so, you need no transformer, just route all the readers into the same writer, like so:
David
  • November 12, 2013
Hi David,
I tried just routing them all into one output CSV, but the output CSV is empty....
  • November 12, 2013
Have you checked that the attributes on the Writer all have a green triangle next to them? This signifies that the attributes are correctly mapped. The triangles should not be red, like this:
David
  • November 12, 2013
HI David,
Yes thanks for that - I don't think I had exposed the attributes correctly!
Thankyou :)
