Hi there I am trying to undertake some spatial validation of input data (points), notably to determine if the ID given to the points is within a polygon with the same ID. Easy so far (PointonPolygonOverlay / Tester).
But what I then want to do for those points that fall outside is calculate the distance to the polygon it should be in. Unfortunately although the point doesn't fall into the polygon it should, it does fall into another polygon so when I run NeighbourFinder all i get is the distance to the nearest polygon, not the one with the matching ID. Can anyone advise if this is the best route or if there is a better way of doing this?
Best answer by david_r
both the BASE and the CANDIDATE must have an attribute in common, i.e. that it must exist with the same name in both datasets.
So if you're using the attribute called "LCS_L1", that attribute must be present in both BASE and CANDIDATE features (all of them). Then only those BASE and CANDIDATE features where LCS_L1 has the same value will be considered by the NeighborFinder.
Which ID do I use, the ID of the base or the candidate, or both? tbh I have tried all three options and I get the following results:
BASE ID = All go through matched, although the close candidate list does not contain the ID of the candidate, just . In addition I know that some IDs in the base do not have an equivalent in the candidate so I don't think this is getting the right result
CANDIDATE ID = All go through unmatched
BOTH = All go through unmatched
Please find below screenshots of the workbench and transformer parameters if that helps?
Ah I see, I had column A (Base) which was LCS_L1, and the corresponding column in the Candidate table was called SITE_ID. Once I renamed these to be the same it appears to be working - many thanks for your help!
