maximum inside rectangle from an polygon
  • Feb 28, 2018 2:23 PM UTC
  • 267 views
michaels
Hi
is there a way to get the maximum inside rectangle from a polygon? I need the rectangle with the biggest area.
Is there a transformer in FME to do this? Or can anyone give me perhaps the python-code to get this rectangle?
thanks for your help
fmelizard
Forum|alt.badge.img+22
  • Mar 2, 2018 5:34 PM UTC
Hi @michaels I found some Python code at https://community.esri.com/thread/182008-how-to-find-the-maximum-rectangle-contained-within-a-polygon Concave polygons are trickier because you'll have to check for intersections as well as iterate through every point (n-1)**2. You might want to start with a Densifier to get more accurate results. But I think it would be best to post this as an idea at https://knowledge.safe.com/content/idea/list.html
