max value of two attribute of a feature
  • Aug 9, 2017 1:27 PM UTC
  • 7 replies
  • 259 views
nmatton
Forum|alt.badge.img+4
Hi !
I have a set of feature, for each feature, multiple attributes (A,B,C), all having numbers. I have to extract, for each feature, the maximum value value among the attributes A,B and C.
Since the StatisticCalculator limit to compute the max/min/... value of an attribute among all feature, how can archive my goal ?
thanks in advance !
erik_jan
Forum|alt.badge.img+26
  • Aug 9, 2017 1:42 PM UTC
Use the AttributeCreator transformer to create a new attribute MAX.
The value will be from the Arithmetic Editor using the function @max() as in the image, where each <FLOAT> is replaced by an attribute value.
Forum|alt.badge.img+63
Shouldn't that be 'max' instead of 'min'?
erik_jan
  • Aug 9, 2017 1:44 PM UTC
Too late, Hans. I saw it and changed the text.
nmatton
  • Aug 9, 2017 2:00 PM UTC
thanks ! that's exactly what's I mean ! was sure that it was a simple way to get this result :)
gio
Forum|alt.badge.img+15
  • Aug 9, 2017 3:35 PM UTC
@nmatton
the statistics calculator can calculate statistics (including max min) for all features, you can simply select them. It will add a prefix to each:
max_feature1,max_feature2 etc.
To get them in a single max attribute you would need to use a bulk attribute renamer with a regex
max_.+ => max
gio
  • Aug 10, 2017 10:38 AM UTC
@nmatton
I see I misinterpreted the question....thanks for the demerit
If you don't want to have to click all the attributes in the max or min function, which is ...
The superior solution then is
nmatton
  • Aug 11, 2017 9:51 AM UTC
@nmatton
That's very nice ! elegant and powerfull when having much more attributes. In my case it's limited to 2... but anyway, I love this way of thinking ! Thanks !
