Mapinfo Table update in FME?
  • Apr 25, 2023 2:27 PM UTC
  • 29 views
edstrat
Participant
Hi all,
Im trying to automate a process done in mapinfo and requires a table update.
The update in question-
imageimageHope this make sense with the censoring however this shouldn't effect the process.
Ive tried a few different ways but i never get the outcome Im looking for.
Thanks.
danminneyatsaf
Forum|alt.badge.img+13
Hi @edstrat​ after looking at some of the documentation on the Precisely site, your steps may look something like the following in FME:
  • Read in the table you want to Update and the table you want to Join with
  • Perform your join using the SpatialFilter transformer since you want to perform an intersect
  • You may need to use the StatisticsCalculator or ExpressionEvaluator to calculate the Proportion Sum of CartesianAreaHa
Hopefully this gives you some more information to help you get started
