Many to Many join using Feature Merger
  • Mar 18, 2020 9:42 AM UTC
  • 504 views
raaaju1990
Forum|alt.badge.img+11
I have two tables having ID column in common. These IDs are repeated multiple times in both the tables. Now I need to merge these two tables into a single table based on this ID field. I tried using Feature Merger, but the results were not as expected. Some data were missing. Is there any effective way to do a many to many join in FME?
Best answer by ebygomm
The FeatureJoiner would be better suited to this, is there a reason for not using that?
Forum|alt.badge.img+54
  • Mar 18, 2020 9:46 AM UTC
@raaaju1990 As @ebygomm suggests try FeatureJoiner.
FeatureMerger is more complex and you probably need to set Process Duplicate Suppliers and also Generate List. Then you need to use ListExploder to split the lists. FeatureJoiner should also be faster.
