Manipulate the Attribute_name with value of a parameter
  • Nov 25, 2020 1:24 PM UTC
  • 105 views
perry
Hello,
Is there a method to combine a STANDARD TEXT with the VALUE of a PARAMETER and use thia as the NAME of an ATTRIBUTE?
The value of the parameter varies with the loop.
Ie:
TEXT : DAYS_
PARAMETER-VALUE : 2017, (next time) 2018, , (next time) 2019
So I want to name the new attribute:
- the 1st time: DAYS_2017
- the second time: DAYS_2018
- the third time: DAYS_2019
etc.
The value of the attribute is calculated by DATE_END-DATE_START in days.
So the output looks like this:
NumberFile DD_START DD_END DAYS_2017 DAYS_2018 DAYS_2019
5124 20180101 20200131 0 365 31
Please response if it is not possible to make an ATTRIBUTE_NAME while looping with parameters.
(I also tried the AttributeDereferencer and attribute exposer and other transformers without succes.)
Thank you,
Perry
jdh
Forum|alt.badge.img+41
  • Nov 25, 2020 2:58 PM UTC
In an attributeCreator in the New Attribute you can put Days_$(param). It will be red in the input box, but the translation should run without issue. Note that since this is a dynamic attribute it won't be visible on the canvas for later transformers to use, but it will be on the feature.
@perry​ If you are trying to transpose data try the AttributeTransposer custom transformer from the FME HUB and look at the article: Transpose a Table Using FME for ideas.
If you have name/value pairs, you can use the same approach described by @jdh​  with attributes using the attribute creator. You can build up the name of the attribute in the AttributeCreator Text Editor.
NameValuePairsParameters are constant for the life of a workspace run, so you might not be able to get a list of dates that you show above.
perry
  • Nov 25, 2020 8:41 PM UTC
Indeed I was confused about the RED in the input-box and that the output was not visible in the canvas as mentioned by jdh.
I have tried a little test with
  • Calculate the days (datetimecalculator) with result attribute DAYS
  • then a attribute_creator and new_value <DAYS_@Evaluate($(JAAR_OUD)+@Value(T_TELLER)) > and value <DAYS>
My firts impression is that it seems to work good:
364 364
Tomorrow I will try to implement this in a loop.
(@Mark: I will surely investigate your tip Attribute Transposer.)
For now: thank you all for your support. 😊
