Making sure all datetime values have time before comparing
  • Apr 27, 2022 3:46 PM UTC
  • 107 views
rtreecare
I'm doing a change detection on a date field from 2 sources. One source always includes time even if they are "000000". The other source appears to be strip those 0's. How can I add the hours minutes seconds to the records that are missing them? Do I need to filter for the records missing time values before adding the 0's. I will attach an image with the "J_NotifyDate" column missing time if they are 0's
Best answer by dustin
So you are wanting to make all null values in the J_CompleteDate field = "000000"? If so, the NullAttributeMapper transformer will be helpful to you.
dustin
Forum|alt.badge.img+36
  • Apr 27, 2022 4:02 PM UTC
rtreecare
  • Apr 27, 2022 4:28 PM UTC
Thanks I think that will work!
