Make line based on distance from single point, and change direction
  • Jul 11, 2018 3:37 PM UTC
  • 8 replies
  • 724 views
Hi. I want to make a line from a single point (based on distance in meter), and then change the direction.
I want to do this for multiple point. I have the line length, x and y coordinates, and line direction.
Line have to start from x and y point.
I'm using FME 2015.
Thanks.
Best answer by takashi
Assuming that each feature has four attributes - (x, y) of the first point, length of the line, and angle representing the line direction. An easy way is:
  1. VertexCreator (Mode: Replace with Point): Create a point (x, y).
  2. VertexCreator (Mode: Add Point): Add a point (x + length, y) to the first point to form a horizontal line with specified length.
  3. Rotator: Rotate the line around the first point (x, y) by specified direction (angle in degrees).
Hi @johsflesj
I'm not sure what the best way to do this would be but I think you may have to go about this in a slightly different way - instead of creating a line and changing the direction I think the best option would be to create the end point first. You can do this by extracting the point coordinates and then using the arithmetic editor, create a second point by adding a distance value to x and y (-/+ will put this point in the right direction) and from there you can join the two together to build your lines.
What is your line direction attribute recorded in? If you know the line length and direction I think it should be possible to work out what values you need to change your original point from.
Hi @johsflesj
In fact using the VertexCreator a line will automatically be created for you if you use the arithmetic editor and input x/y +/- these new distances. So the only hurdle here is calculating the values to add to x and y - finally school maths might actually come in handy!
jdh
Forum|alt.badge.img+41
  • Jul 11, 2018 7:07 PM UTC
Attached in an old custom transformer, since the last save version is 2014, it should be okay on 2015.
pointfrombearing.fmx
Note that this only really works in Cartesian coordinates. If you are in lat/long and covering large distances, you need to use a more complicated equation.
  • Jul 12, 2018 9:30 AM UTC
Hi @johsflesj
Thanks for answering. The direction is recorded in degrees.
  • Jul 12, 2018 9:59 AM UTC
  • Jul 12, 2018 1:36 PM UTC
This way worked perfectly. Thank you so much!
Here is what i did:
  • Jul 12, 2018 1:48 PM UTC
Can some please explain me why VertexCreator (Add point) creates a line?
  • Jul 12, 2018 2:57 PM UTC
So, I made the data doing this:
The problem now is that only a few lines got the right direction. Most are pointing eastwards, when the direction deegree is for example 10 or 359.
Does anyone know?
