Make a short wide table into long thin
  • December 12, 2016
  • 199 views
I am trying to convert a table with 5k rows and 115 columns of data into a long table. I have 5 columns to fix and then about 100 which I want to take the column name and put that into another column and then have the values of that column in a field called Regs.
I've attached a sample excel file with what I'm wanting to do.
Thanks
Mark
Best answer by todd_davis
attributeexploder is the main transformer you want, as it will crate the column name as an attribute and the vale as another attribute and separate each into a value into a seperate feature.
todd_davis
Forum|alt.badge.img+23
  • December 12, 2016
todd_davis
  • December 12, 2016
Here is an example skinny.fmw
  • December 13, 2016
That's great. Thanks. It works perfectly.
