Loosing z-values at Bufferer - how to avoid?
  • Dec 7, 2017 4:54 PM UTC
  • 174 views
Hi all,
I'm trying to create a Mesh out of Esri Shape polylines. I have shape files from a public transport network and need them as a 3d model (FBX). The single lines do not have the same z-values, they are changing. You can find my workbench in the attachments. Unfortunately the ascii grid file is too big to upload here.
My workbench "works", i'm getting an FBX but i loose the z-values at the bufferer, so my Model is extruded but all lines are on the same altitude. After some research i found the 3DBufferer (Now Hub3DBufferer) but FME stopps the translation after around 1h with the following messages:
Extruder_Rejector(TestFactory): Extruder_<REJECTED> Feature Counter -1 2147680263: Failed to seek to beginning of `%0' -- perhaps there is not enough disk space
Failed to seek to beginning of `C:\\Users\\Clement\\AppData\\Local\\Temp\\no-conn-ffs-1512660184987_17620.ffs' -- perhaps there is not enough disk space
I have 120GB of disk space, so i'm not sure what's the problem.
I asked this in a comment in the following, but old thread as well:
https://knowledge.safe.com/questions/4918/bufferer-for-polyline-with-z.html
Has anyone an idea how to avoid loosing the z-values? Many thanks for all inputs.
Cheers
  • Dec 8, 2017 10:34 AM UTC
Hi @uaclement, how about draping the buffer areas, rather than the source lines?
  • Dec 10, 2017 2:56 PM UTC
Hmm, i'm feeling a little dumb now, not to have tried this before ;)
It works, thank you takashi.
jhu_20
Forum|alt.badge.img+12
  • Aug 29, 2018 3:51 PM UTC
I got the similar error message when using HttpCaller to download data from a web site in Json format. The diskspace for E: drive is not an issue. Any suggestions ?
Failed to seek to beginning of `E:\\FME_TEMP\\Enervest_V2_Producing_Entity_Stats_R5_102256\\inspector.ffs' -- perhaps there is not enough disk space
jhu_20
  • Aug 29, 2018 3:52 PM UTC
I got similar error message when downloading and loading data using HttpCaller from a external web site. Any suggestions ?
