Looking for sample python code to replace Database Uploader - SQL Server
  • Jan 24, 2020 4:08 PM UTC
  • 70 views
salvaleonrp
Forum|alt.badge.img+23
I have these parameters for database Uploader transformer and I'd like to do the same thing on a python shutdown script so I don't need to have a parent and child workspace for capturing log information. Looking for some python samples to do this with SQL Server. Thanks.
  • Jan 27, 2020 9:28 AM UTC
Rather than using a shutdown script, why not replace the writers with FeatureWriters and connect the DatabaseUpdater to the Summary output port? You can use the DateTimeStamper and the DateTimeCalculator to calculate the duration.
salvaleonrp
  • Jan 27, 2020 2:48 PM UTC
I did not think hard enough. I have a Date time stamp as part of my shutdown script even if it's not necessary for what I wanted to do. Since I knew that the Session duration will only be logged upon completion of the workbench file, I insisted to get that the info come from the log file itself. Thanks, this comment answered a few other things that would complete my solution.
  • Jan 27, 2020 3:06 PM UTC
Glad to hear and happy to be of help. The FeatureReader / FeatureWriter pair is exceptionally useful and allows you to easily implement a lot of common usage patterns within a single workspace, often with no coding (compared to using startup and shutdown scripts).
