loading Data Interop project into Workbench
  • May 23, 2017 4:41 PM UTC
  • 84 views
I would like to load one of my old Data Interop files into Workbench... but first of all, I can't find where the project file actually lives - it doesn't come up on a search for *.fm*.
If I look at "C:\\Users\\mcreamer\\AppData\\Local\\Safe Software\\Interoperability\\ArcCatalog-20160810-130827" I can see log files.. but nothing that looks like content.. or no pointer to another path. Can someone help?
  • May 25, 2017 2:59 PM UTC
Hi @jazz_swings, as far as I know, a workspace created with Esri Data Interoperabirity for ArcGIS Desktop is saved as a part of the toolbox file (*.tbx) and you cannot open it with FME Workbench directly. If you open the tbx file with a text editor, you can see that the workspace is contained within it.
  • May 26, 2017 3:22 PM UTC
The only work around I know for this is to open both the interop and fme applications on the same computer then select all the objects in the interop workbench, copy and paste into the fme workbench.
Thank you @guidos and @takashi
