Linear Referencing Speed along line / Event CSV and Line Geometry
galigis
Forum|alt.badge.img+16
Hi All,
I have been trying to put a workflow together to linear referencing a few event tables in GIS. I usually do the task in ArcGIS but this time I want to automate the process as much I can.
I have been checking a few of the LRS FME tutorials online but can’t get it to work. The aim is to linear referencing speeds along a railway route (line) using an event table that relates the lines and speeds.
The input of my workflow as follows:
  • Event table (xls) that shows the Line and speeds, example below:
  • Line geometry with the line ID as well the ‘From_Chain’ and ‘To_Chain’ fields as parts of the attribute
I have got to this point in the automation but can’t get the Snipper to work for some reason since doesn’t split the lines according to the speed lengths:
Any advise how to accomplish the task?
Thanks
birgit
  • March 11, 2025
Does your geometry actually have measures on them?
Feature attributes as seen in the Inspector
Also check this page:
galigis
  • March 12, 2025
Thanks ​@birgit I think I have made a few changes and the workflow seems to do what I want now. Below a breakdown of the transformers used to do the trick:
  • MeasureGenerator for the Line
  • FeatureMerger to join table and line by Line_ID. Generate List ticked on with all the attributes selected.
  • List Exploder
  • Snipper
  • LineonLineOverlayer to remove the duplicates / overlaps
Also below an screenshot of the workflow:
I hope this helps! :)
