Linear referencing: How to create point/line geometry from route event table?
  • Mar 27, 2018 3:11 PM UTC
  • 6 replies
  • 281 views
I need to create a point/line geometry out of the following input data:
a) route: line geometry stored with measure values, including a route id field
b) point/line event table without geometry, including a reference on the route id field, a measure value field (point event) / a start and an end measure value field (line event)
Is there an existing transformer or a common known routine in FME to solve this problem?
Best answer by david_r
I you merge the two input datasets (FeatureMerger on the route id), you can use the Snipper with snipping mode = "Measure (value)" to "snip" or to cut your route geometries to a start/end value.
lars_de_vries
Forum|alt.badge.img+10
Here's a great example of how to use Linear Referencing in FME!
  • Mar 27, 2018 3:26 PM UTC
  • Apr 3, 2018 3:58 PM UTC
Thanks for your help and the sample workbench. This worked well!
  • Apr 20, 2018 11:22 PM UTC
@david_r Can I get a copy of the sample workspace, too? I need to do the same thing.
  • Apr 23, 2018 6:19 AM UTC
I'm sorry, I don't have any sample workspace for this.
But feel free to post your case as a separate question, I'm sure someone can help.
  • Sep 24, 2018 10:02 AM UTC
Here's a sample of how I solved it (comments in German).
