LINE TO POLYLINE
  • January 31, 2013
  • 84 views
tbs_gis_team
I need to be able to change 2 point lines that are in a source file to poylines to be wrtoe to an SDF writer. I need this so I do not have to types of lines in my final exported file.
Thanks,
Chad
Best answer by davideagle
Hi Chad...
  • CoordinateCounter, then
  • Tester - set it to _coordcount = 2
    • FAILED = allow features to continue to SDF output
    • PASSED = Add a LengthCalculator, then
  • Followed by an ExpressionEvaluator set to @Value(_length)/2, then
  • A Densifier set to densify with an Interval based on the _result attribute from your ExpressionEvaluator.
That process adds an extra node to your 2 noded lines, in the middle to make them have 3 nodes! Now you have all polylines... Drop a GeometryOGCValidator on the end to make sure you have all valid geometry...
Hope that works for you.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
davideagle
Forum|alt.badge.img+21
  • January 31, 2013
Hi Chad...
