Line entities no longer appear in the output Dwg file under FME 2018
  • Apr 21, 2020 12:28 PM UTC
  • 0 replies
  • 59 views
Hello, I have made corrections to a Dwg file, except that in the output Writer, my lines have disappeared, it no longer appears in the output Dwg file. All other block type entities are displayed except the line type entities.
However the missing lines belonging to the layer EP_GEOREF_SOUT_GAINE_PLEINE (190 entities) appear well in the transfer but it does not appear in the output dwg.
Do you have a solution or the parameter which makes it possible to display the lines in the Dwg in output writer?
thank you in advance
