line builder with condition and Geometry cleaning
  • Jun 13, 2019 8:23 AM UTC
  • 7 replies
  • 137 views
franco69
Forum|alt.badge.img+11
Hi Guys,
i know maybe this was asked before and i searched the forum for this but i was not really successful in finding....if there is the same question please llink it:
After my last post i have now set up a workbench which brings me following result:
i have now 744 lines with same length of 1600m e.g with always a 50m shift
first line begins 0 to 1600
next from 50 to 1650
next from 100 to 1700 and so on
in an attribute i have stored a class number (1,2 or 3)
so line 1 to line 16 class1
then from 17 to 21 class2
22 to 51 class 1 and so on
but i have of course duplicate geometry always (with this shift)
so i want long segments (and no duplicate geometry any more) where the class is the same BUT:
on duplicate geometry parts i want to keep the line with the higher class
i have part where i have class 2 and class 3 e.g.
so i want the delete the geometry parts with 2 there and keep one with 3...
hope i was clearly with my description otherwise ask me
Greetz and Thanx
Franco
Best answer by jdh
If you send your lines through an Intersector, generating a list containing the class value. You can then sort the list based on the highest class (ListSorter) and promote the first value (ListIndexer, 0).
That should give you a line set with no overlaps, containing the highest class value. You can then send that to the LineCombiner (combine on attributes - class).
jdh
Forum|alt.badge.img+41
  • Jun 13, 2019 3:03 PM UTC
franco69
  • Jun 14, 2019 7:07 AM UTC
@jdh...i have tried it already with the Intersector...but it doesn't give me the result i want.
for example....
i have 4 lines class3
first line from 200 to 1800
second from 250 1850
third from 300 to 1900
fourth from 350 to 1950
so in this case i want to hold a line from 200 to 1950 with class 3 BUT:
there are lines with class 2
e.g.
from 400 to 2000
from 450 to 2050
from 500 to 3000 and so on
a Intersector gives me 50m segments
so class3 from 200 to 400.....
and from 400 to 1950 i get segments with class 2
and that is wrong
so Intersector is euther the false Transformer or i haven't chekced a param inside the transformer i can use for that
Greetz
Franco
jdh
  • Jun 14, 2019 3:47 PM UTC
for example....
e.g.
from 400 to 2000
from 450 to 2050
and that is wrong
Greetz
Franco
The default setting on the Intersector for Attribute Accumulation Mode is Use Attributes From One Feature. That will give you the value of a random feature when there are multiple overlaps, which is not what you want.
That is why I specified you need to generate a list. Which will produce a list element for every overlapping feature. You can then sort the list to have the highest class be the first element.
trevorm
Forum|alt.badge.img+3
  • Jun 14, 2019 4:42 PM UTC
I'm guessing your measures are of lines on top of each other?
What about the Dissolver ? Set Group By: Class
I had something similar and it worked for me!
  • Jun 15, 2019 4:28 AM UTC
for example....
e.g.
from 400 to 2000
from 450 to 2050
and that is wrong
Greetz
Franco
Perhaps what you are missing is to set the class number to the Group By parameter in the Intersector.
franco69
  • Jun 17, 2019 9:06 AM UTC
@jdh
after this the result is the right one...BUT: i don't exactly udnerstand why?
why i have 32 more features after the Intersector (exactly one segment long)?
what exactly happens in the ListSorter and ListIndexer Transformer then?
i want to undertsand this...
Greetz and Cheers
Franco
jdh
  • Jun 17, 2019 2:06 PM UTC
@jdh
Greetz and Cheers
Franco
The intersector will break apart features at intersections, including co-linear overlaps.
So if you had two non-parallel features that intersected each other at a single point, you would end up with 4 features.
If you had two features that partially overlapped one another (your case), you would end up with 3 features: the non-overlapping portion of each of the original features, as well as a single feature for the overlap.
By default, the overlapping segment will be assigned the attributes of one of the original features. Since we can't guarantee that's the 'higher class', we want to keep all the attributes from all the overlapping features so we can determine the higher class.
The generate list option on the intersector allows up to keep all the overlapping attributes.
Since you want the highest, the easiest way to analyse the list is to sort it, so that the elements on the list are ordered by the class value. That way the attributes from the feature with the highest class is guaranteed to be the first element in the list.
The listIndexer takes one element of the list (we want the first, so index 0) and 'promotes' it to regular attributes.
Original Data
Class: 1
Class:2
After Intersector
_list{0}.ID: A
_list{0}.Class: 1
_list{0}.ID: A
_list{0}.Class: 1
_list{1}.ID: B
_list{1}.Class: 2
_list{0}.ID: B
_list{0}.Class:2
After ListSorter
_list{0}.ID: A
_list{0}.Class: 1
_list{1}.ID: B
_list{1}.Class: 2
_list{0}.ID: A
_list{0}.Class: 1
_list{0}.ID: B
_list{0}.Class:2
After List Indexer
Class: 1
Class:2
Class:2
