Limit attribute value to 8 character
  • Feb 23, 2022 7:19 AM UTC
  • 5 replies
  • 256 views
abinash
Hi, i have a attribute field that contains value more than 8 charecter.I want to limit it to 8.
Best answer by david_r
You can use the SubstringExtractor for this.
  • Feb 23, 2022 7:21 AM UTC
abinash
  • Feb 23, 2022 7:32 AM UTC
Actually i have the value starting from 1 to a number which contains more than 8 character. so i want something like attribute rounder so that i could mention the maximum digit.
  • Feb 23, 2022 7:49 AM UTC
Can you provide some examples.
abinash
  • Feb 23, 2022 8:03 AM UTC
i need a transformer which will limit the attribute value to 8. if there is any value more than 8 character it should erase the extra value on the right side
abinash
  • Feb 23, 2022 8:59 AM UTC
i found it (string length formatter )
Thank you
