Latitude Longitude Conversion
  • October 28, 2019
  • 792 views
I have X and Y coordinate in a csv file and i want to change the coordinate system to LL84. Is there any way to convert these number ?? Any help will be much appreciated.
  • October 28, 2019
Have a look at the CsmapAttributeReprojector to convert attribute values directly to LL84.
Alternatively first create geometries out of the X/Y values (either in the CSV reader or using the VertexCreator) and then using the CsmapReprojector or any of the other "specialty" reprojection transformers.
becchr
Forum|alt.badge.img+25
  • October 28, 2019
Not sure if you can do it directly on the attributes, but for sure you can:
  1. Make vertices from your CSV with VertexCreator
  2. Use the Reprojector transformer to transform your data from original to new projection
  3. Get the new coordinats as attributes if you want with the CoordinateExtractor
