Latitude and Longitude DMS 2D Point Replacer
  • August 21, 2013
  • 99 views
I'm a beginner to FME and I apologise if this seems like a basic or an obvious query.
I have an excel spread sheet and one of the columns contains the coordinates in a DMS format e.g. N51.48.27 W03.22.24. How would I create a point from this coordinate?
I’m familiar with 2DPointReplacer and I have used it before; so as a hunch, my next step was to split the coordinates into latitude (51.48.27) and longitude (-03.22.24) columns. However, these are still not recognised as an easting and northing format when using 2DPointReplacer.
Please can someone point me in the right direction? My ultimate goal is to create a .shp file in a British National Grid coordinate system.
Thanks
Shaun
Best answer by david_r
I think you will have to split each part of the values into three separate attributes ("51.48.27" -> "51", "48" and "27"), then use the DecimalDegreesCalculator transformer to get the lat/lon values for the 2DPointReplacer.
Look at the help for the DecimalDegreesCalculator for some hints on how to split the DMS string.
David
  • August 21, 2013
David
  • August 21, 2013
Thank you David! Spot on! That did the trick.
Shaun
