LAS tansformation and local coordinate system
  • Jan 10, 2017 2:41 PM UTC
  • 6 replies
  • 167 views
j_geo
Hello,
I am a researcher from Slovenia. I'm having huge trouble working with Slovenian datasets,
as they are in EPSG:3912 or EPSG:3794. These two systems are not supported by FME.
I solved this for shapefiles by using ESRIReprojector. But it does not seem to work
with las datasets.
I am trying to extrude footprints using LIDAR data and convert that to KML, which needs WGS84 data.
Is there a sollution? I am quite surprised that FME does not support all EPSG projections.
I even tried to add custom coordinate system and was not successful.
Regards!
Jernej
bruceharold
Forum|alt.badge.img+19
  • Jan 10, 2017 3:21 PM UTC
You may need to add your coordinate systems:
http://docs.safe.com/fme/2016.1/html/FME_Desktop_Documentation/FME_Coordinate_Systems/Workbench/coordinate_sys_custom_about.htm
Oh I see you tried that.
ArcGIS cannot reproject LAS data sets, but you could convert them data to point and back after reprojection.
itay
  • Jan 10, 2017 6:27 PM UTC
Hi @jernejtekavec, You are on the right path that is to say to add the custom coordinate systems and then reproject. I would advise you to contact support for some help on introducing the coordinate systems.
daveatsafe
Forum|alt.badge.img+24
  • Jan 10, 2017 9:11 PM UTC
@jernejtekavec,
I have created a couple of custom coordinate systems for you:
Slovenia1996.SloveneNationaGrid (EPSG:3794)
MGI/gc.SloveneNationalGrid (EPSG:3912)
Please unzip the attached file into your Documents\\FME folder to add the coordinate systems to FME.
definitions.zip
krostir
Participant
  • Participant
  • Jun 13, 2017 2:58 PM UTC
@jernejtekavec,
definitions.zip
Both coordinate systems are working as expected. Could they be included in the FME release?
  • Aug 12, 2020 1:45 PM UTC
@daveatsafe​ Hello, could you please send me the zip in question too? I am too working with EPSG: 3794 and having issues. Thank you.
daveatsafe
  • Aug 12, 2020 4:57 PM UTC
Hi @matija​ ,
The link in the post above has been fixed, which should allow you to download the definitions from it.
