LandXML - ProfAlign
  • Nov 12, 2013 8:57 AM UTC
  • 0 replies
  • 47 views
habbu
Forum|alt.badge.img+4
Dear all
My LandXML (1.2) dataset contains an Alignment with a Profil class, including ProfSurf and ProfAlign elements.
Reading the ProfSurf elements is no problem, but FME doesn’t read the ProfAlign elements.
Is it possible to read the ProfAlign elements?
My current solution is to edit the XML file and change the ProfAlign element to a ProfSurf element. It’s ok for the moment, because I don’t need more precision, but I would like to use the LandXML file without editing.
Best regards
Hartmut
