LabelPointReplacer looses z-value
  • Jul 29, 2024 2:57 PM UTC
  • 177 views
jeroenpeters
Forum|alt.badge.img+5
It appears the LabelPointReplacer removes the z-value from 3D point features and replaces it with NaN. I’m using FME Form 2024.0.3.0 as our IT-department isn’t fast enough with the updates 😑. Does anyone know if this is fixed in a newer version? Now I 3D-force it with the old z-value.
Best answer by DanAtSafe
Hi @jeroenpeters I see that the z-value wasn’t changed in FME 2022, but with FME 2023+ and version 6 of the LabelPointReplacer, it gets replaced with nan.  FYI, I have filed FMEENGINE-83651 about this.
DanAtSafe
Forum|alt.badge.img+23
  • Jul 30, 2024 6:44 AM UTC
jeroenpeters
  • Jul 30, 2024 6:57 AM UTC
Thanks @daveatsafe 👍
andreaatsafe
Forum|alt.badge.img+17
Hi ​@jeroenpeters ,
I’m pleased to let you know we’ve fixed this issue in FME 2024.2.
Z-values will now be retained when using the LabelPointReplacer.
