Keep only unique value on a concatenate attribute
  • September 6, 2017
  • 8 replies
  • 173 views
Hi everybody,
I've a new question, I'm creating a "concatenate attribut" with an aggragator, and I would like to only keep unique values on that concatenate attribut.
At the moment, I've this kind of results "0.1,0.1,0.1,0.2", and I would like to just keep "0.1, 0.2".
I've tried a lot of things, with lists etc... but I failed, to find a way to do that.
Do you have any advice to do that ?
Kind regards,
Nicolas
Best answer by david_r
Weird, works for me:
Before:
`_list{0}' has value `0.1'
`_list{1}' has value `0.1'
`_list{2}' has value `0.1'
`_list{3}' has value `0.2'
After:
`_concatenated' has value `0.1,0.2'
`_list{1}' has value `0.2'
Since you're having floating point numbers, are you sure they're 100% identical? Remember that e.g. 0.1 and 0.099999 won't be treated as a duplicate by the ListDuplicateRemover.
  • September 6, 2017
If it's a list, have you tried the ListDuplicateRemover before concatenating?
  • September 6, 2017
Thanks @david_r, no it's not a list.
But I tried to generate a list with the aggregator and then, use a ListDuplicateRemover, but it didn't work
Forum|alt.badge.img+39
  • September 6, 2017
If it's not a list already then an AttributeSplitter, followed by a ListDuplicateRemover then a ListConcatenator is probably the way to go
  • September 6, 2017
Before:
After:
erik_jan
Forum|alt.badge.img+18
  • September 6, 2017
I tried the same approach and it works for me too:
Just to be sure: your decimal delimiter is not a comma (same as the values delimiter)?
  • September 6, 2017
Hi @nmeriotdev, to clarify what happened when you tried the ListDuplicateRemover, can you post the list contents logged by Loggers?
Insert two Loggers before and after the ListDuplicateRemover like this, and run.
Then, post the result shown on the Translation Log window, like this.Before
Logger: Feature is:
Feature Type: `Logger_LOGGED'
Attribute(encoded: utf-8): `_list{0}.attr' has value `0.1'
Attribute(encoded: utf-8): `_list{1}.attr' has value `0.1'
Attribute(encoded: utf-8): `_list{2}.attr' has value `0.1'
Attribute(encoded: utf-8): `_list{3}.attr' has value `0.2'
After
Logger_2: Feature is:
Feature Type: `Logger_2_LOGGED'
Attribute(encoded: utf-8): `_list{1}.attr' has value `0.2'
  • September 7, 2017
Sorry I wasn't at the office. So with your answers I've deleted/create again everything and now it work. I think I was just missing the list concatenator after the duplicateRemover.
Thanks a lot guys.
Nicolas
gio
Forum|alt.badge.img+15
  • September 7, 2017
@nmeriotdev
Regexp Replace
([^-]*)(-\\1)+($|-)', '\\1\\3')
Change the delimiter to your needs. Objects must be sorted.
