KAFKA porvides a file. What's next?
  • Feb 2, 2022 3:37 PM UTC
  • 93 views
The KAFKAConnector works fine und provides me features with a filename "key"and the file itself "value". In my case "value" holds a zip-file with Shape-Layers.
How can I access the features in the zip-Files?
The content of "value" starts e.g.:"504B0304140008080800117242540000000000000000000000000C00000036313231396E67722E646266A4BD49AEB5C9921C5622454D04021A68016F2EBC83E89B2121160942608352092047DA8776A389D629B3F81AF76391F578322A1F2A2BF2FEFFBDD74F34DE9A9BFFCBFFE75FFC8B7FF53FFEDDDFFDBFFFC3FFF777DB3FFFCBDFFDDDBFF987BFFF37F77FFD3BFEEB7FFD57DF7FE5BFFCFD3FFC87FFF8F7FFF8F7FFF04FFCF9BFFF87FFEB3FFDDBFF7B2DFF13FFF53....
I think, I have to write this somehow to the filesystem. Maybe using the FeatureWriter Format: DATAFILE
And then use the FeatureReader.
Any Ideas?
regards
Herfried
Best answer by caracadrian
Use AttributeFileWriter with "value" as Source Attribute and "key".zip (if it is a zip) to Target Filemane.
Then use ZipExtractor and FeaureReader if you need to access the data.
caracadrian
Forum|alt.badge.img+23
  • Feb 3, 2022 6:45 AM UTC
  • Feb 3, 2022 7:38 AM UTC
Or simply read the data directly from the zip, if the format reader supports it (most file-based readers do).
caracadrian
  • Feb 3, 2022 8:06 AM UTC
Thanks for reminding me of that option!
  • Feb 3, 2022 4:22 PM UTC
Thank you for your help.
The AttributeFileWriter and FeaureReader work fine and I will go with that.
Maybe one day there will be a solution without a detour over the filesystem.
