JsonTempater Geometry template usage
jurgenmack
Forum|alt.badge.img+9
I have created a geojson file from nine features drawn from a postgis database. I have tried all the examples from the community pages with no success. Can anybody point me in the right direction?
Best answer by daveatsafe
You can do this with a simple PostGIS to GeoJSON workspace, with the GeoJSON writer option ‘File Structure’ set to ‘Array of FeatureCollection objects - one per feature type’.
danilo_fme
Forum|alt.badge.img+45
  • February 10, 2024
Hi @jurgenmack
Do you have the geoson created? If yes, could you share us?
Thanks
jurgenmack
  • February 10, 2024
I should have said I’m trying the create a geojson. It writes out but this geometry template doesn’t do anything.
jurgen
danilo_fme
  • February 11, 2024
jurgen
Hi Jurgen, thanks your answer.
Please, could you share your workspace template.
jurgenmack
  • February 12, 2024
I am trying but for some reason it will not let me upload the file.
Jurgen
jurgenmack
  • February 12, 2024
Here is a screenshot of my JSONTemplater settings.
jurgenmack
  • February 13, 2024
Finally, here is the workbench. Can someone have a look and see what i am doing wrong. I am trying to include the geometry in the output geojsn file but none of the examples i have tried when configuring the geometry template in the JSONTemplater have worked.
jurgenmack
  • February 14, 2024
@danilo_fme I have posted the workbench template.
Thanks Jurgen
virtualcitymatt
Forum|alt.badge.img+36
Is there a reason you want/need to use the Templator as opposed to just the GeoJSON Writer? Does FME not create the correct structure from your featuers?
jurgenmack
  • February 14, 2024
I have a dataset that has multiple features and I was hoping to generate one json file instead of one for each feature.
daveatsafe
Forum|alt.badge.img+19
  • February 14, 2024
daveatsafe
  • February 14, 2024
Adding modified workspace to illustrate
jurgenmack
  • February 14, 2024
@daveatsafe I had no idea it was that simple. I’m always looking for the most complicated workflows. I’m going to have to change the way i develop workbenches. Start with the simplest solution first. (Reader 2 Writer nothing between)
Thanks Dave,
PS. For future reference is there anything wrong with the way i am setting up the Geometry Template?
Jurgen
daveatsafe
  • February 14, 2024
Working with the geometry template can be quite complex. You can see more information on it at https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/XQuery/XQuery_functions.htm. It would be a lot easier to use the GeometryExtractor to extract the geometry as GeoJSON, then insert that attribute into the template using:
"geometry" :fme:get-json-attribute("_geometry")
