JSONFragmenter raises error if specified file path contains spaces
Hello,
FME 2019.0.1 build 19253
I noticed the JSONFragmenter raises an error if the specified file path contains spaces.
JSONFragmenter (JSONQueryFactory): The clause 'FILEPATH_OR_URL folder name/test-geojson-structure.json' within 'FACTORY_DEF * JSONQueryFactory FACTORY_NAME JSONFragmenter INPUT FEATURE_TYPE Creator_CREATED MODE EXPLODE EXPLODE_FORMAT JSON REJECT_EMPTY_LISTS YES EXTRACT_ATTR No JSON_ATTR <Unused> READ_FROM_FILE YES FILEPATH_OR_URL folder name/test-geojson-structure.json OUTPUT_ATTRIBUTE _result EXPLODE_QUERY json<openbracket><quote>features<quote><closebracket><openbracket>*<closebracket> RECURSIVE_FLATTEN <Unused> OUTPUT EXPLODED FEATURE_TYPE JSONFragmenter_FRAGMENTS OUTPUT REJECTED FEATURE_TYPE JSONFragmenter_<REJECTED>' is incorrect.  The parameter to FILEPATH_OR_URL must be a constant value, a value-of (&) attribute, or an FME function call
See also the attachment:
Best answer by mark2atsafe
These transformers now allow use of a filename with a space in them. It will be in any build 19621 or greater (so 2019.2 or even 2019.1 if a newer version such as 2019.1.2 is posted). No word on using an attribute for the parameter though.
mark2atsafe
Forum|alt.badge.img+46
Thanks for letting us know, Takashi. I've filed this as an issue with the developers and I hope that they will fix it soon.
The reference number for the issue is FMEENGINE-60151
Regards
Mark
mark2atsafe
Regards
Mark
I notice that it also affects the JSONExtractor and JSONFlattener, so I've mentioned that to the developers as well.
  • May 22, 2019
Regards
Mark
Hi @mark2atsafe, thanks for filing the problem report.
Additionally, I think it would be a good enhancement if an input feature attribute could be set to the File/URL parameter optionally.
mark2atsafe
  • September 3, 2019
  • September 4, 2019
Good to hear. Thanks for the fix and you notification.
