JSONFlattener w/ Arguments
  • Dec 22, 2017 3:59 PM UTC
  • 59 views
Hello: I have a surveymonkey survey responses that I have to loop through to capture all of the responses from 1 page. I capture the number of responses from an attribute returned from the GET from the API endpoint and I use that as my loop counter. My question is can I loop through the response body and pass the loop counter to capture the next survey response on this page? For instance, if I have data{}.id as an attribute, in a JSONFlattener can I dynamically set the value within the {} to @Value_count? Any help is greatly appreciated.
danilo_fme
Forum|alt.badge.img+58
  • Dec 22, 2017 11:53 PM UTC
Hi @bcrowley10,
For the count the number os elements of a list you can use the transformer ListElementCounter.
You can try to use before the transformer JSONFlattener.
Thanks,
Danilo
