JSON Templator Correct Syntax
deanhowell
Forum|alt.badge.img+23
I need to output a list of paired values as a JSON File.
I have a list called JSONList with two attributes JSONname and JSONvalue.
I am using the JSONTemplater to organise the data.
I have the root template set as
  "publishedParameters": [
    fme:process-features("SUB")
and the SUB Template as
  "name": fme:get-list-attribute("JSONList{}.JSONname"),
  "value": fme:get-list-attribute("JSONList{}.JSONvalue")
but I am just getting the name and value as a single line each.
How do I change the structure so each name and value pair are separated, similar to the below?
      "name": "_portalLayer",
      "value": "parks"
      "name": "_portalOrganisation",
      "value": "SWR"
Best answer by takashi
Hi ​@deanhowell ,
A simple way is to extract elements of the JSONList{} with ListExploder beforehand, then set this expression as the SUB template in the JSONTemplator.
  "name": fme:get-attribute("JSONname"),
  "value": fme:get-attribute("JSONvalue")
[Addition] Alternatively, using XQuery syntax, this Root template expression is also possible, without using SUB expression.
    "publishedParameters" :
        let $names := fme:get-list-attribute("JSONList{}.JSONname")
        let $values := fme:get-list-attribute("JSONList{}.JSONvalue")
        for $i in (1 to count($names))
        return
            "name" : $names[$i],
            "value" : $values[$i]
crutledge
Forum|alt.badge.img+33
  • May 5, 2025
Hi ​@deanhowell
I am curious how to do this as well. Seems like it is taking the whole list and writing out as one line where we want it create a record set of pairs. if we did this by hand we would do something like:
  "name": fme:get-list-attribute("JSONList{0}.JSONname"),
  "value": fme:get-list-attribute("JSONList{0}.JSONvalue")
  "name": fme:get-list-attribute("JSONList{1}.JSONname"),
  "value": fme:get-list-attribute("JSONList{1}.JSONvalue")
But we want it to iterate through the list like:
  "name": fme:get-list-attribute("JSONList{n}.JSONname"),
  "value": fme:get-list-attribute("JSONList{n}.JSONvalue")
I am sure there is a simple straight forward solution. I will share if I get something working. Good luck!
  • May 5, 2025
Hi ​@deanhowell ,
        return
deanhowell
  • May 5, 2025
Thanks ​@takashi great advice as always. I was just over complicating things and had a list builder in the process, which wasn’t needed.
