JSON Templater - support for boolean values?
  • Jul 1, 2019 9:10 AM UTC
  • 170 views
lazarlubomir
Forum|alt.badge.img+11
Hello everybody,
because of specific demand I have to use JSON templater -> TXT writer workflow. But, when I need to export values true/false as boolean data type, JSON templater still put me there quotation marks for values true/false - so result is "True" or "False".
Please, has anybody idea, how to figure it out to write bool values without quotation marks?
Thank You so much!
Lubo
Best answer by takashi
If a feature attribute (e.g. called "attr") stores 1, 0, "true" or "false", this template expression converts the value to a boolean value - true or false without quotations.
    "attr" : xs:boolean(fme:get-attribute("attr"))
stalknecht
Forum|alt.badge.img+22
  • Jul 2, 2019 7:41 AM UTC
Can you share the template you are using?
  • Jul 2, 2019 1:08 PM UTC
lazarlubomir
  • Jul 2, 2019 2:36 PM UTC
@takashi Thank You so much!
jpvo
  • Jun 8, 2021 3:12 PM UTC
Thank you takashi!
