json templater conversion
  • Jul 16, 2020 3:03 PM UTC
  • 6 replies
  • 48 views
gis2020
Forum|alt.badge.img+5
Hi All,
I am trying to create json file using the json templater . input for this file has postGIS file with geometry in wkt format . i tried to convert using json templater but it not giving the desired output . can somebody help me with this ? i am uploading the json format file which is my desired output for this . file name examplebody.json
also i am attaching the screenshot of the out put which i am getting.
  • Jul 16, 2020 3:08 PM UTC
Looks like you should be using the GeoJSON writer rather than the text writer. That way you can also leave out the JSONTemplater.
If needed, you should first use the GeometryReplacer to convert the WKT to an FME geometry.
gis2020
  • Jul 17, 2020 7:02 AM UTC
thank you david . i tried using geojson writer but still i get the different output. below is the screenshot of desired output.
  • Jul 17, 2020 7:42 AM UTC
Can you show us what you got using the GeoJSON writer?
gis2020
  • Jul 17, 2020 9:19 AM UTC
sure . this is the output i am getting using the Geojson writer.
My input has two geometry columns as geometry 1 and geometry 2 which is a same geometry but with time stamps .
  • Jul 17, 2020 5:01 PM UTC
Any particular reason for storing the geometries as text attributes in addition to the regular GeoJSON geometry definition?
Also I'm not sure GeoJSON allows for multiple geometries such as this. Is there any chance that you create an aggregate geometry of geometry_1 and geometry_2 and use that instead?
  • Jul 20, 2020 1:31 PM UTC
Hi @gis2020, I think this workflow generates your desired result if each input feature contains a line geometry.
JSONTemplater Root Expression:
    fme:process-features("SUB")
JSONTemplater SUB Expression:
    "geometry"||fme:get-attribute("_count") : fme:get-json-attribute("_geometry")
Alternatively, this would work as well.
    for $g at $i in fme:get-json-list-attribute("_list{}._geometry")
    return
        "geometry"||$i : $g
