JSON Reader Folder - Get File name
akoure_terracon
Forum|alt.badge.img+3
I’m using the JSON reader to read in a folder of JSON files. The reader is working how I want it to, however I would like to get the original file path/name as an attribute on each feature.
Is there an easy way to do this? I’m hoping that I am missing something silly.
Best answer by danilo_fme
Hi @akoure_terracon
 I think you that you can expose the format attribute fme_basename in Reader.
danilo_fme
Forum|alt.badge.img+42
  • April 2, 2024
Hi @akoure_terracon
akoure_terracon
danilo_fme wrote:
Hi @akoure_terracon
Thanks Danilo! The filename without extension is in the fme_basename attribute, and the full file path is under fme_dataset.
danilo_fme
  • April 2, 2024
akoure_terracon wrote:
danilo_fme wrote:
Hi @akoure_terracon
You are wellcome!
