JSON - packing arrays on Templater.
  • Jun 24, 2016 9:59 AM UTC
  • 62 views
jorge_vidinha
I'm trying to pack 2 simple valid arrays of objects in an json object inside a Templater.
Happens that out of the templater my result seems to get interpreted as a string addin some strange characters  \n   {\n
May i be missing some json logic here ? thanks
array_1
      "att1" : "DUT",
      "att2" : null
array_2
      "att1" : "DUT",
      "att2" : null
      "att1" : "DUT",
      "att2" : null
Object packed at Templater with expression:
      "array_1" : fme:get-attribute("array_1"),
      "array_2" : fme:get-attribute("array_2")
Result
{ "array_1" : "[\n   {\n      \"att1\" : \"DUT\",\n      \"att2\" : null\n   }\n]", "array_2" : " [{\n      \"att1\" : \"DUT\",\n      \"att2\" : null\n   },\n{\n      \"att1\" : \"DUT\",\n      \"att2\" : null\n }]\n" }
Best answer by takashi
Hi @jorge_vidinha, the reason is that you are using get-attribute function though the attribute values are JSON objects. Try using get-json-attribute function instead.
  • Jun 24, 2016 11:04 AM UTC
jorge_vidinha
  • Jun 24, 2016 11:21 AM UTC
Mr. Takashi. Thank you !.
You have solved me the json challenge puzzle. Let the fme votings of the day be with you.
