JSON Flattener issue - selected value isn't being turned into an attribute?
  • Nov 19, 2026 2:54 PM UTC
  • 19 views
parke372
Forum|alt.badge.img+11
Hello all, i’m using FME workbench 2025.1 and JSON Flattener.
the schema looks like:
"$schema": "https://json-schema.org/draft-07/schema",
"title": "Generated Schema",
"description": "Generated from JSON data",
"type": "object",
"properties": {
"Events": {
"type": "array",
"items": {
"type": "object",
"properties": {
"Id": {
"type": "string"
"Deleted": {
"type": "boolean"
"EventId": {
"type": "integer"
"InformationText": {
"type": "string"
"CategoryId": {
"type": "integer",
"enum": [
12,
13,
9
"CategoryDescriptor": {
"type": "string",
"enum": [
"Fault",
"High",
"Status"
"State": {
"type": "string",
"enum": [
"Acked",
"ReadyToBeReset",
"Unprocessed"
"Cause": {
"type": "string"
"SrcPropertyId": {
"type": "string"
"SrcObservedPropertyId": {
"type": "string"
"SrcState": {
"type": "string",
"enum": [
"Active",
"Quiet"
"Timer": {
"type": "string",
"format": "date-time"
"SrcSystemId": {
"type": "integer",
"enum": [
2,
3,
4,
5
"SrcViewName": {
"type": "string",
"enum": [
"ApplicationView",
"ManagementView"
"SrcViewDescriptor": {
"type": "string",
"enum": [
"Application View",
"Management View"
"SrcDesignation": {
"type": "string"
"SrcLocation": {
"type": "string"
"SrcName": {
"type": "string"
"SrcDescriptor": {
"type": "string"
"SrcDisciplineId": {
"type": "integer"
"SrcDisciplineDescriptor": {
"type": "string"
"SrcSubDisciplineId": {
"type": "integer"
"SrcSubDisciplineDescriptor": {
"type": "string"
"CreationTime": {
"type": "string",
"Direction": {
"type": "string"
"InfoDescriptor": {
"type": "string",
"enum": [
"BACnet Priority: 64 - BACnet Notification Class: 3 ",
"Configuration Outdated"
"InProcessBy": {
"type": "string"
"Commands": {
"type": "array",
"items": {
"type": "object",
"properties": {
"Id": {
"type": "string"
"_links": {
"type": "array",
"items": {
"type": "object",
"properties": {
"Rel": {
"type": "string"
"Href": {
"type": "string"
"IsTemplated": {
"type": "boolean"
"minItems": 0
"required": [
"Configuration",
"EventId",
"Id",
"ValidationRules",
"_links"
"minItems": 0
"MessageText": {
"oneOf": [
"type": "array",
"items": {
"type": "string"
"minItems": 0
"type": "array",
"items": {}
"DesignationList": {
"type": "array",
"items": {
"type": "object",
"properties": {
"ViewId": {
"type": "integer"
"Descriptor": {
"type": "string"
"required": [
"Descriptor",
"ViewId"
"minItems": 0
"DescriptionList": {
"type": "array",
"items": {
"type": "object",
"properties": {
"ViewId": {
"type": "integer"
"Descriptor": {
"type": "string"
"required": [
"Descriptor",
"ViewId"
"minItems": 0
"SourceDesignationList": {
"type": "array",
"items": {
"type": "object",
"properties": {
"ViewId": {
"type": "integer"
"Descriptor": {
"type": "string"
"required": [
"Descriptor",
"ViewId"
"minItems": 0
"minItems": 0
i’m specifically hoping to pull out
“MessageText”
my flattener is configured like this:
but when i use list exploder, none of the messagetext properties are exposed as attributes:
even though there is message text:
"Events": [
"Id": "MSU_S4:GmsDevice_1_770500_9.Alarm.OffNormal:_alert_hdl.2._value~639306771647900000~11911~5753",
"Deleted": false,
"EventId": 5753,
"InformationText": "",
"CategoryId": 9,
"CategoryDescriptor": "High",
"State": "Unprocessed",
"Cause": "Low Limit (-258.50 ppm)",
"SrcPropertyId": "MSU_S4:GmsDevice_1_770500_9.Alarm.OffNormal:_alert_hdl.2._value",
"SrcObservedPropertyId": "MSU_S4:GmsDevice_1_770500_9.Alarm.OffNormal:_alert_hdl.2._value",
"SrcState": "Active",
"Timer": "0001-01-01T00:00:00Z",
"SrcSystemId": 5,
"SrcViewName": "ManagementView",
"SrcViewDescriptor": "Management View",
"SrcDesignation": "ManagementView.FieldNetworks.FTB_BT.Hardware.FTB05PXM.Local_IO.FTB_HVAC13_RaCo2",
"SrcLocation": "Project.Field Networks.FTB BT.Hardware.PXM_05_PXM (Old AEM MBC05).Local_IO.0 TO 2000",
"SrcName": "FTB_HVAC13_RaCo2",
"SrcDescriptor": "0 TO 2000",
"SrcDisciplineId": 50,
"SrcDisciplineDescriptor": "Building Automation",
"SrcSubDisciplineId": 0,
"SrcSubDisciplineDescriptor": "Unassigned",
"CreationTime": "2026-11-19T14:26:04.79Z",
"Direction": "None",
"InfoDescriptor": "BACnet Priority: 64 - BACnet Notification Class: 3 ",
"InProcessBy": ""},
"MessageText": [
"\r\n FTB_HVAC13_RaCo2 (0 TO 2000) -258.5 ppm *A3F*unAC NONE \r\n (Limit Exceeded: 0.00)"
parke372
  • Nov 19, 2026 5:05 PM UTC
I’ve been continuing to poke at this here and there. found with JSON Extractor i CAN get the message text out with:
json["Events"][*]["MessageText"][*]
