JSON AttributeExposer get subgroup value
  • May 4, 2018 10:57 AM UTC
  • 23 views
Hi all,
I hope an easy one.
Please see attached images;
how should I write to get the values within the measures item in the AttributeExposer tool?
Many thanks
jkr_wrk
Forum|alt.badge.img+37
  • May 4, 2018 12:15 PM UTC
I think your problem is like:
https://knowledge.safe.com/questions/58375/how-to-change-list-to-attribute-with-listindexer-t.html
You wan't to get the list element with index 0 into a attribute.
If the list is always of length 1 (index 0) you could use a AttributeRenamer to rename meassures{0}.parameter to parameter.
